Incoherent mesh on edges
Dear Autodesk Team,
Could you please let me know what kind of error of mesh on edges like picture below :
Sometime I see the mesh have a blue line so I can't manually correct the mesh. Please let me know clear , thank you very much.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Could you switch on display of node numbers and surface element numbers and switch off filling of panel interior so that it is easier to see what is on the picture?
Artur Kosakowski
Hi Artur, here is the picture ,
I also upload my file at link below
https://indochine-my.sharepoint.com/personal/phuckha_indoeng_com/_layouts/15/guestaccess.aspx?docid=...
Thank you very much for your help
Hi Artur, Could I have your explain ?
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
When you switch on display of node numbers and surface element numbers and switch off filling of panel interior so that it is easier to see what is on the picture ... Smiley Wink
Artur Kosakowski
