Impulse load on hanging pendulum
TorgrimO
TorgrimO
I have a hanging structure subjected to impulse loads (wind pressure) from passing vehicles. How should I go about analysing the behaviour of the structure from one load impulse? I.e. a transient analysis where I can apply an impulse load on the structure to see the behaviour of it and how it swings after the load is applied. Are there any tutorials or other material regarding this subject? Thanks.
@TorgrimO  Artur Kosakowski marked the post as the solution. If it did not work as an answer, please post your reply in this thread so that I can unmark the solution.
Muhammed.OPERA
Muhammed Mamdouh (OPERA)
Structural Engineer, Instructor
Facebook |LinkedIn
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @TorgrimO
Please check these links:
AKN:  ROBOT - how to set up blast , explosion, impact load in Robot: https://knowledge.autodesk.com/support/robot-structural-analysis-products/troubleshooting/caas/sfdca...
Robot Forum:   Definition of Blast accidental loads in Robot: https://forums.autodesk.com/t5/robot-structural-analysis-forum/definition-of-blast-accidental-loads-...
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @TorgrimO
I just wanted to  ask if you found the links I posted helpful.
Artur Kosakowski
