Hi there,
Simple question i believe, I am importing a dxf file from Autocad into Robot, the lines are coming up but the point coordinates which I have drawn as "Points" on Autocad aren't. I can't believe that Robot can't import point coordinates, what am i doing wrong?
I have attached the dxf below.
Solved by Rafacascudo. Go to Solution.
just link these points with lines in autocad , import and these points will be in Robot as nodes. then just delete the created bars in Robot.
Rafael Medeiros
