Import SAP2000 file to Robot
I am trying to import a SAP2000 file to Robot version 2019.
I follow the next procedure:
1. Export the SAP2000 file to a .s2k. Therefore i have a folder with the .s2k and the .sdb file.
2. I open robot then open project. I select the .s2k file. The program tells me to save the file with .str format and i do it. The programs throws the message: Incomplete conversion of the structure geometry. Unkown node -TABLE. See Image 1
3. I click close, and an error message pop, and asks if i want to see the error. I click yes. Then a .str fiule appears. See Image 2 and file.str.
The .str and .s2k files are in the Robot.7z file attached
I read in the forums that i cannot import .s2k files containing "tables". If this is true, what should i do to import correctly the SAP2000, and if not, what i am missing out?
Thank you very much in advance.
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
Exactly. I am sorry.
Rafal Gaweda
is there any solution? What...!!!   Has  Autodesk no solution ??? !!! please ...you have got many programmer...
InterbuildEng
the solution is just use SAP instead of Robot.
