Import multiple elements in PRM
Μηχανικος
Μηχανικος
Is it possible to import multiple elements in the provided reinforcement module at once?
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Μηχανικος
Yes, you can do so. I'd recommend watching the recording of 4th RSA webinar where this was demonstrated.
Artur Kosakowski
Μηχανικος
Ok you are right, i watched the part for columns and then i rushed to design some beams without watching it.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Μηχανικος
Mind that a chain of bars is recognized as a multi span beam so be careful with selections so that you don't create one beam instead of e.g. two separate ones.
Artur Kosakowski
Μηχανικος
got it
