I don't see imperial bar sizes displayed not even characteristic strenght
can advise why
Solved by adelmoparigi. Go to Solution.
I guess you have edited the bar database.
There is an issue with editing bar database with imperial units. Simply, we loose the information about units and its is treated as SI units.
Please remove edited copy of the database bar_ACI 318-08.xml from this location:
"c:\Users\%local_user%\AppData\Roaming\Autodesk\Structural\Common Data\2022\bar_ACI 318-08.xml"
I'm sorry for inconvenience, the issue will be fixed.
This issue has been resolved with Robot Structural Analysis Professional 2023 release.
Please find more in the Release Notes
Regards
Autodesk Robot Structural Analysis team
