Ignore analysis warning -Save as default-RSA 2023
ArunNDinesh
Message 1 of 8
ArunNDinesh
Hi ,
Please help to close the warning pop-up automatically when you run the analysis.
This pop-up is coming up again during analysis if you close and reopen the ROBOT model, even though you sets as "save current parameters as default" in job preferences.
Replies (7)
Message 2 of 8
Romanich
Hi @ArunNDinesh ,
Can you please share a screenshot of the warning?
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Message 3 of 8
okapawal
This is an issue in the program that "Ignore analysis warning" settings are not serialized with a file and preferences.
We will fix the issue.
Waldemar Okapa
Sr Product Owner
Message 4 of 8
ArunNDinesh
Hi @okapawal
It would be nice if "Ignore analysis warning" settings are also serialized.
When you reopen a ROBOT model and run the analysis in background  and this pop-up stops the analysis with warnings and  unless you press "ok" or "Esc" or you need change save settings for each ROBOT model which is tedious when you work on many models in a day.
Can't this setting be updated in RSA 2023 at least please?
@Romanich Please see the trail post for screenshot.
Message 5 of 8
Romanich
Hi @ArunNDinesh,
The option to switch off/on automatic verification has been available last 10 years using the Windows registry trick. Please find attached the prepared reg files for version 2023. More info (in Russian, sorry)
Roman Zhelezniak
Message 6 of 8
ArunNDinesh
Hi @Romanich
That's great! Its been a while I'm using RSA and I didn't noticed this "registry" trick. Thanks for this😊
But I don't want ROBOT to skip "structural verification". Just want run automatically with verification and stability warnings.
Also this reg file is switching off only "structural verification" and not the "analyisis warning". please see the screenshot below after running your reg file.
I know this warning can set to "ignore analysis warning" in job preferences. But that needs to be done each time when I open a new ROBOT model.
Please suggest
Message 7 of 8
okapawal
This issue has been corrected in Robot Structural Analysis 2024 release. Release notes
Implemented change keeps  "Ignore analysis warning" setting in Job Preferences.
Waldemar Okapa
Sr Product Owner
Message 8 of 8
ArunNDinesh
@okapawal
Thank you for incorporating the issue in 2024 edition.
Hoping to use the version soon
