If you try to create Autodesk Robot Structural Analysis models basing on DWG/DXF background, it is now possible to profit from next enhancements in IgentForm software, namely possibility to change lines, which create beams and walls (with openings) on 2D view into 3D objects, with automatic recognition of elements widths and adjusting elements ends for proper creation of calculation model. (IgentFormDXF1EN.png attachment)
IgentForm automatically adjusts defined elements to requirements of parametric defintion, by automatic creation of axes and internal lines.
Mode of points definition has also been improved for all programs from IgentForm parametric software family.
IgentDraw software for parametric creation of reinforcement drawings has been improved according to customer's remarks. It is now possible to automatically get clear drawing even for complicated reinforcement regions (IgentDrawI4.png attachment)
NOVELTY - IgentPres it is a new member of parametric software family, created at the request of one of large companies from Warsaw, basing on IgentForm and IgentDraw interface. Thanks to it, it is possible to create easily 3D models of complicated arrangements of prestressed tendons, basing on DWG/DXF backgrounds, with different number of strands and anchorage details. After saving file into IFC format, it is possible to get 3D model of prestressed tendons f.ex. in Autodesk Revit. It is especially important for public buildings, where BIM requirements starts to be obligatory. (attachment IgentPres1EN.png)
