I've noted a small problem in RSA 2016
Message 1 of 14
I have installed RSA Professional 2016 in win 10. I have noted that in the steel design the calculation window is parcially cut as shown in the screen cpature attached. Has someone had the same problem?
Replies (13)
Message 2 of 14
Artur.Kosakowski
Autodesk Support
Autodesk Support
Have you installed SP4 for RSA 2016
Artur Kosakowski
Message 3 of 14
Thank you for asking. Yes, I installed SP4.
Message 4 of 14
Artur.Kosakowski
Autodesk Support
Autodesk Support
What is your screen resolution and text size settings?
Artur Kosakowski
Message 5 of 14
Thank Arthur. My resolution is 2560 x 1440 and my size text is 200%.
Regards
Message 6 of 14
Artur.Kosakowski
Autodesk Support
Autodesk Support
Is it the same when you set 100% ?
Artur Kosakowski
Message 7 of 14
Unfortunately it is the same for any text size. Any other idea please?
Regards
Juan
Message 8 of 14
Artur.Kosakowski
Autodesk Support
Autodesk Support
Without changes in the internal code of RSA responsible for the way this table is displayed the only option I can think of is to reduce the resolution of the monitor.
Artur Kosakowski
Message 9 of 14
Artur.Kosakowski
Autodesk Support
Autodesk Support
Regards
Juan
Hi Juan,
As I checked on the computer with the same resolution and 100% text size that the table is dis[played correctly let me ask you if you actually restarted your machine after changing from 200% to 100% ?
Artur Kosakowski
Message 10 of 14
Thank you Artur,
While I was trying to solve the problem I found the the Display dialog box is not working properly in win10 as shown in picture attached. Could please help me also with this?
Regards
Juan
Message 11 of 14
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi Juan,
I have checked on the monitor with the same resolution as yours and as far as I can see when you set text size to 100% (mind that you need to restart computer to apply this change) the dialog is displayed correctly.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Message 12 of 14
As you said, changing the size of the text fixes the mentioned dialog box problems. I really appreciate your help. However, I would like to suggest elaborate a bit more this issue in the future since 100% text size in conjunction with a high resolution makes the text dificult to read  in a 13" laptop screen.
Thanks again.
Juan
Message 13 of 14
Artur.Kosakowski
Autodesk Support
Autodesk Support
Yes, we have noticed this situation. Thank you.
Artur Kosakowski
Message 14 of 14
okapawal
The issuse has been corrected in Robot Structural Analysis 2020.1 Update
Waldemar Okapa
Software Quality Assurance & Testing Engineer
