I'm trying steel moment connection design - working forces or factored one?
Hi
Can someone tell steel moment connection design procedure in Robot. I'm trying steel moment connection design in Robot first time never done this before. Does it need to provide working forces or factored one?
M
@Anonymous Artur Kosakowski edited the topic from 'Steel Moment Connection design - beam connecting to column web' for better findability and marked post as the solution. If it did not work as an answer, please post your reply in this thread so that I can unmark the solution.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
The later.  assuming that you design according to Eurocode you need to use the ULS (with load factors) combination type.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
What about with India codes?
Also for connection design is there is any option to see forces given for connection design are correctly applied or not as the calculation report generated do not show this. Is there is any option to see free body diagrams which shows force distribution and directions etc
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
The Indian codes is not supported in the steel connection module.  Could you attach a sample of the report as you would like to see it?
Artur Kosakowski
pls see attached
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
After calculating the connection press the indicated button. Then you can add this dialog to the report as the screen capture if required.
If one or more of these posts answered your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Artur Kosakowski
