How to turn off mesh nodes only?
I want to be able to see the numbers of my geometry nodes and the meshing on panels but I don't want to see the node numbers created by meshing.
Is this possible or is it a case that you either have all node numbers shown (including from mesh) or none.
thanks
Artur.Kosakowski
Autodesk Support
Autodesk Support
Do you have to see panels or will it be enough to see surface elements only?
Artur Kosakowski
Surface elements would do I guess. I just don't want to see the meshing nodes, when the mesh is not on. For example, below, I want to be able to see elements nodes only and not the whole lot.
thanks
Anyone? How can I turn off the mesh nodes after meshing a panel but still be able to see geometry nodes???
Artur.Kosakowski
Autodesk Support
Autodesk Support
Only if you select the nodes you want to see plus bar elements (but no panels) and open them in a new window.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
That's a pain...
thanks
william.howes
Community Visitor
Community Visitor
I would recommend going through the 'Member Selection' tool and highlighting all the members which you would like to see the nodes for. Close this and then open the 'Node Selection' tool, click the drop down for the types and attributes and click 'Member'. This then only highlights the nodes adjoining the members you highlighted earlier. Hope this helps.
