Good morning Autodesk team,
I'm actually on a project where I have to size s massive reinforced concrete stack. It is 150m high, 20m wide at the top and the bottom and its foundation in like a wind turbine. No problem to model the foundation, except support, but I don't know to model the stack. I tried with a cylinder and then apply a specific thickness on it, but It doesn't work.
After that, I would like to know how to size the whole element, can I get some reinforcements or does it work like a simple reinforced concrete element, for example a wall?
Thank you for your attention.
Hugo W.
Rafael Medeiros
Please find a analogy in attachment. It's not the stack I want to model, but it shows you how it can look like.
The attached drawing is not quite clear - but it seems that it can be modeled as a shell structure.
Is my guess correct that it is a set of 5000mm diameter steel pipes packed inside load/carrying RC structure?
If this post answers your question please click the "ACCEPT AS SOLUTION" button (the button visible when logged to the forum). It will help everyone to find answer more quickly!
