How to run a calculation (API)
Hello !
I would like to lauch a calculation without opening the file manually. Is it possible to do it with windows command line or with the API ?
Thank you very much,
Gregoire.
Romanich
Hi @Anonymous ,
Did you try Calculation Manager?
https://help.autodesk.com/view/RSAPRO/2022/ENU/?contextId=IDD_ROBOT_CALC_MANAGER
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Yes I tried, but i still need to choose my file and click on "Execute".
I was wondering if it was possible to do something like "robot.exe calculate file.rtd result_path.rtd", or to use API to load a file a do the calculation.
rsousa_
Hi @Anonymous
Yes, you can do it easily with ROS API. Please see the tutorial, where you can see this example, that do exactly what you need
'Declare auxiliary constants for the file name in which RTD task is stored and for the name of the new file in which the calculated project will be saved.
Const filepath = "c:\myproject.rtd"
Const newfilepath = "c:\myprojectnew.rtd"
' 	Declare and create the main object representing the Robot program.
Dim robapp As IRobotApplication
Set robapp = New RobotApplication
' 	Open the project.
robapp.Project.Open filepath
' 	Start the calculations.
robapp.Project.CalcEngine.Calculate
' 	Save the project under a new name.
robapp.Project.SaveAs newfilepath
' 	Close the project.
robapp.Project.Close
' 	Free the object representing the Robot application.
Set robapp = Nothing
Regards
