Custom Section Not Displayed Correctly
EduardoMeruvia
EduardoMeruvia
Hi all,
I'm currently using Robot 2022 with the latest patch and I seem to be having a problem with how Robot its displaying some of the custom section I've created via the Section Definition module.
In the Section Definition Module, I've created the custom section shape as shown below;
Custom Section Shape CreatedCustom Section Shape Created
Section appears to calculate correctly with no errors or warnings at all during this stage.
However, once I save this section into my user database and assign it to a member, the section shaped displayed by Robot its incorrect. However, the correct section property values appear to be there (Iy, Iz, Vy, etc) it just seems a "display" error.
Robot model attached for reference also.
Appreciate any help.
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @EduardoMeruvia
I have opened your file (RSA 2022 HF1) and I see the follwing. Seems to correspond to defined section shape.
Krzysztof Wasik
Krzysztof_Wasik
Autodesk Support
Autodesk Support
HI @EduardoMeruvia
I am also able to add this section to my User database (from your model). It is presented as follows
and can be used in new projeects.
Krzysztof Wasik
EduardoMeruvia
Hi @Krzysztof_Wasik ,
Thanks for the prompt response. Not sure what happened there, but I restarted my PC and re-open the same file and it also worked for me.
Might have just been something with my temporally with my PC.
Thanks again for the response.
