How to resolve minimum bar spacing in a Flat Slab
aliyuaziz
aliyuaziz
I am getting 'For panel no. 71 the minimum bar spacing:   4.0 [cm] < 4.5 [cm] is exceeded.' error message. Any guidance on how to resolve it?
Any verification results for flat slab design to compare with that of robot?
Thanks a lot.
Aziz
Artur.Kosakowski
Autodesk Support
Autodesk Support
Increase rebar sizes to allow for larger spacing for the same area of reinforcement or increase panel thickness to reduced required are of reinforcement.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
aliyuaziz
Hi Autur,
Many thanks. That helps.
Aziz
