How to remove isolated nodes on solid´s elements
victorjusten
Message 1 of 11
victorjusten
Hi
At verification/analysis I get messages that there are isolated nodes. I am new to Robot and am finding it hard to detect and remove these nodes. When I click the warning they dont show on the screen and furthermore are not selected so that I can delete them. How can I resolve this problem ???
Replies (10)
Message 2 of 11
Rafal.Gaweda
Autodesk Support
Autodesk Support
Message 3 of 11
victorjusten
Follow the file....
http://www.filemail.com/d/mabmwuyfoykmwov
Thanks !!!
Message 4 of 11
Rafal.Gaweda
Autodesk Support
Autodesk Support
Open file in repair mode
Delete isolated nodes
Correct rigid link
Corrected file attached.
Rafal Gaweda
Message 5 of 11
victorjusten
Thanks a lot !!!
I have some questions about this model that you sent to me. I saw that you made a fixed support on joint 6511 (a joint that i used as the master on rigid´s link to transfer the loads to the entire structure). I suppose that the fact of using this joint as  the master does not mean it is connected to structure. If i go to "ANALYSIS / VERIFICATION " i receive an alert that there are isolated nodes on this model that you sent to me, but the software runs the calculation normally.
Thanks !!!
Message 6 of 11
Rafal.Gaweda
Autodesk Support
Autodesk Support
My mistake. Delete this support.
Rafal Gaweda
Message 7 of 11
victorjusten
Hi Rafal !!!
I´ve tried to do what you told me, but when i go to Analysis / Verification and check the "ISOLATED NODES" and click "DELETE", the nodes don´t delete. I went to VIEW/ DISPLAY and check "DISPLAY ATTRIBUTES ONLY FOR SELECTED OBJECTS"  but the isolated nodes don´t appear. How did you do to delete this isolated nodes in this model ?
In the model that you sent to me, i observe that the model have 1 isolated node (NODE 6511 - the master of the rigid link) but this model run the calculation normally.
Thanks a lot !
Victor
Message 8 of 11
Rafal.Gaweda
Autodesk Support
Autodesk Support
This way:
Rafal Gaweda
Message 9 of 11
victorjusten
Thank´s Rafal !
Message 10 of 11
This screen cast is unavailable. Would you please reload it?
Message 11 of 11
jhe55NCY
I'd like to see it too please
