How to print cartography on big paper format
antoine.carimalo
antoine.carimalo
I am trying to pring catography of the whole slab of a 35x30 meters building in plan.
All the finite elements résults must be displayed, not only the extremums, so I need a big paper format.
Is it possible to do that? How could I do?
Cordially
Antoine
Artur.Kosakowski
Autodesk Support
Autodesk Support
1. Set page size as e.g. A-0
2. Display a map with values (or only values) selecting finite elements centers. Press Page Down severa times to reduce the size of the text as much as possible
3. If values are not shown for each surface element use the mouse wheel to zoom in (enlarge certain part of the slab) and then refresh the view. You should have values displayed on all surface elements that are within the enlarged part of the panel
4. Use the mouse wheel to zoom out till you see the whole panel. The values should be visible for every surface element
5. Make screen capture either in as PNG or copy to clipboard with max. available resolution
6. Print the screen capture from the printout composition (png) or paste the picture to e.g Paint and print from there.
Artur Kosakowski
antoine.carimalo
Very usefull tips ! thx so much.
