Hello everyone, I have applied the supports to Panel (Rigid, Uz). However, results are displaying reactions on FE nodes. Now, I need to obtain the reaction on the base for which I need to make sum of these nodal reactions but it is too huge work considering the numerous nodes and every time I modify model, I need to repeat this step. Is there any exiting tool/ trick to do this? Also, the direct summation will be be inaccurate in case of non linear analysis i.e. Seismic analysis. Thanks in advance for your help.
Solved by puneet.gupta12. Go to Solution.
Solved by Refaat. Go to Solution.
instead of using elastic support, use panel with foundation elasticity
Don't forget to delete elastic supports before applying new thickness
M. Agayr
Hi @puneet.gupta12 ,
If you need to know the total, go to the end of the Reaction table:
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
Sorry about my previous post , I expected you need linear reaction .
In your case , click on the right button of your mouse to get the tables then select ( Plates and shells) as in the capture below .
Thank you for your reply. This option is useful to check global reaction, but i have several panels for which i want to find the reactions.
I don't know the stiffness parameters of Foundation. I will try to follow your advice for a test in simple model to know how it will be working. Thank you.
You can get only the panel reaction as I mentioned if you used elastic panel support .
If you used (Rigid support under the raft ) then you can get the total panel reaction as Roman suggested. Snice you have different panels then you may defined your supports with different names for each panel . Then you can get the sum for each one of them separate .
@Refaat Thank you very much for your help. So I went ahead and used foundation stiffness on Panels and deleted the supports. Now I can see the reactions on these panels but only in Static cases. Do you know how can I obtain the reactions in seismic cases and combined cases. See below snapshots. Best regards, Puneet
@Refaat Thank you very much for your help. So, I followed your advice , but I am still unable to obtain the reactions in seismic load cases. sorry but due to confidential information I can not share my main model, but i am sharing a simplified test model on which i usually makes tests. Thanks in advance for knowledge sharing and sharing your expertise.
@Refaat thank you once again. I have already applied the foundation stiffness to the panels which will be blocked in vertical direction. In reality, the structure is supported on 9 vertical column, 8 Peripheral supports (including 4 at corners) and 1 at middle of structure. The arrangement is bolted and there is a huge clearance so these supports (9 supports), will only block structure movement in Vertical direction i.e. UZ=0. Accordingly, I have applied the foundation stiffness on these 9 panels.
Additionally, there are four supports out of which each two supports will block structure in X and Y directions respectively. For that, I have linked the base plate of the supports to a common node using Rigid links and I applied supports on the common node accordingly. This structure and the boundary conditions is more or less identical to the original structure. Could you please now help if I am doing it correctly. Best regards, Puneet Gupta
Check this macro
Thanks to @Krzysztof_Wasik for the screencast. Elastic supports - reactions and Planar support.
@Refaat thank you to you as well. I was finally able to follow your solution. @Rafal.Gaweda Thanks for your API. the next would be to implement your code.
