How to modify the name of the beam or any member in robot
Djokaboris
Message 1 of 11
Djokaboris
Hi;
Some questions please
i) Is there any way to modify a member name as in a GA plan in robot??, tried to modify in the geometry window at the left of the image but it's freezed
ii)for beam reinforcement is there any way to force robot to create a hook at the bottom reinforcement on both
sides
Replies (10)
Message 2 of 11
Rafacascudo
Changing the name
Before
after
Rafael Medeiros
Message 3 of 11
Simau
Hi @Djokaboris
ii)for beam reinforcement is there any way to force robot to create a hook at the bottom reinforcement on both sides
M. Agayr
Message 4 of 11
Djokaboris
Many thanks Sirs ,
A last querry please, there are a lot of locations  that beams are not visible(don't know why). Try inserting it but still can't be shown.
Message 5 of 11
Simau
Could you specify storie or beams number that are not visible?
M. Agayr
Message 6 of 11
Djokaboris
For every stories Sir. Is there a reason for this non visibility??
Message 7 of 11
Djokaboris
from the panels, there are beams non visible that i inserted from my recent files . But now even when i recreate the section it's still not there
Message 8 of 11
Djokaboris
It's from the day the RSA files was freezing Sir @Simau , and you fixed it. please is there a reason why i can't insert the RC beam section in those locations??
Message 9 of 11
Simau
@Djokaboris
Sorry but I don't remember having solved this kind of problem.
Could you tell us for example between which nodes you can't insert RC beams
M. Agayr
Message 10 of 11
Djokaboris
Example of some location on the  story TO floor.  For other story there are still no beams that should support some panels
Message 11 of 11
Simau
@Djokaboris
Take a look at this link
https://help.autodesk.com/view/RSAPRO/2025/ENU/?caas=caas/sfdcarticles/sfdcarticles/Is-it-possible-t...
M. Agayr
