- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I modelled a building in Revit and exported it to RSA. I have expansion joints where two close columns share a pad foundation in Revit. In RSA these were modelled as separate bases. I get a separate structure error message when I run the analysis. How can I connect the two columns to a common base in the building design module?
Am I to use rigid links? If so, how do I select which node will be the master and which will be the slave?
Or is the correct approach to model the separate sections individually and then manually combine the support reactions outside RSA? This seems a bit tedious, especially when there are many load combinations.
Please advise
