How to model circular water tank?
Hi there
I want to model and simulate circular water tank with 45m diameter and 7m height.
I have watched many videos about that and my questions is:
1-Can I model the tank as circle shell or the wall should be small parts of rectangular walls??
2-If it possible how to model it??
3-How to define a shell or wall with small thickness at top and thin at the bottom of the wall?
4-Where can I find videos or PDF to learn more about ROBOT?? or the best resource to be professional on this program?
Rafacascudo
1- circle will be always a poligonal in Robot
2- Many ways to model
     1- Geometry/objects/ cylinder , but you´ll have no control to assign different thicknesses to wall ,base and top slabs/plate
     2- You can create a circle and use extrude option on Geometry/objects/extrude
     3- I would do as below
Don´t forget to delete the bars used to help build the panels
3- Yes ,watch the video
4-   http://forums.autodesk.com/t5/robot-structural-analysis/robot-vault-lots-of-information-for-new-user...
Build your Robot Structural Analysis IQ - YouTube
Rafael Medeiros
Thanx so much.
But I want to know why I can't assign the shell first before the foundation??
Also why did you draw the bars and divide the shell to two parts??
Rafacascudo
1-You can assign the thicknesses in any order.
2- You have to set a closed contour ,but the  vertical segment cannot be the same bar.So for cylinder walls it has to be divided in 2.
Rafael Medeiros
