Critical Buckling Load
Hi all
My question here is how ARSA determines the side to calculate the critical load
It takes the Imax instead to calculate the Imin to calculate the critical load, in fact this may lead to wrong results
See the attached *.rtd file
The critical Load for Iz is perfect (equals the Euler value), but the real critical load must be for the Iy side.
For Rafal and Pawel
The files send under this link
I want to calculate the critical load for this model, the smaller file ...1408s is a simplification of the another
(The shell elements are deleted, the beams are from the catalog and there is only one load case left)
I need some advice to avoid the error 5000
Defined a nonlinear combination for (Permanent + Live + Wind)
I set the buckling parameters for the 50 modes
Best Regards
Marcelo
