How to model 2 different slab thickness within a panel, aligned to top of the beam
nusl1
nusl1
Anybody to guide me how to model beam and 2 different slab thicknesses aligned to the top of the beam?
There are 185mm thick slab at the panel perimeter and 350mm thick slab at the centre of the panel.
A sketch showing the desired arrangement and Robot model is attached. @Artur.Kosakowski
Romanich
Hi @nusl1,
Maybe this will help:
https://forums.autodesk.com/t5/robot-structural-analysis-forum/api-macro-creation-of-quasi-t-amp-l-r...
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
vanny.zerlina
you can use on tab geometry-objects-polyline(contour). before you draw the polyline, insert grid on the location of diferent slab.
Simau
@nusl1
Create yous slab and beams at neutral axis levels.
Before meshing your slabs, create some nodes on beams and slabs perimeter and join these nodes with rigid links
M. Agayr
nusl1
@vanny.zerlina Thanks for your reply. I'm able to draw slabs but the problem is to keep the top level of both slabs aligned to the top of the beam.
nusl1
@Romanich Thank for your reply. Even I use T & L beams, I'm not sure how I can support 350mm thick mid slab which is away from bar element. Perhaps need to use rigid links between T or L beam and 350 slab?
nusl1
@Simau. Thanks for your reply. Yes. This is a good solution even though it needs to create many rigid links.
