How to fix illogical results.
abidlihouda
abidlihouda
Please can anyone help me to figure out how to fix these illogical results on RSA ! I tried to change more than parameter but it just doesn't work ! Thanks.
Check de dimension of the structure. it seems too big. look to the unity formats.
abidlihouda
Hi @Anonymous
Yes you're right !! I imported a .dxf file and I forgot to check units. Thanks a lot for your note. But even after this rectification, I still have problems with results !! There's no buckling check for columns for example.
Buckling parameters.pngBuckling results.pngStructure1-UnitsRectified.pngBeam result.png
I found this link: https://knowledge.autodesk.com/support/robot-structural-analysis-products/troubleshooting/caas/sfdca... explaning causes of the "no buckling design" but I still don't know how to figure out this issue.
Thank you.
You dont have compression in the bar for the combination you calculate. If you check for exemple for the case 2, it will check it automatically.
