Announcements
Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
How to design unrestrained beam with Robot
8 REPLIES 8
Message 1 of 9
Tmanzz
450 Views, 8 Replies
Need some guidance please.
Currently designing a steel grillage to support point loads.
The intention is for each beam to bear on 2 columns at the ends only.
So only the bottom flange will be fixed down at the supports.
What is the best way to do this with robot?
I suppose i want to design the beams as unrestrained.
Also, if I insert intermediate beams along the length of the main beam, can those be taken as laterally restraining the main beam?
Model attached.
If there is any video that explains this, can someone please direct this to me.
Thank you.
8 REPLIES 8
Message 2 of 9
Romanich
in reply to: Tmanzz
Hi @Tmanzz,
https://youtu.be/GhP9An47EKw?list=PLY-ggSrSwbZqow_60fiqJwS69mg1nQMzk
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Message 3 of 9
Krzysztof_Wasik
in reply to: Tmanzz
Hi @Tmanzz
Restrains for beam, considered while design, are defined in steel code check parameters assigned to that beam
Please refer to
How to limit lateral buckling length (LTB) for steel code verification, and take into account adjoin....
and
How to define correctly lateral buckling length for steel beam divided in several segments in Robot ...
I would also recommend the following tutorial (Steel design parameters are discussed from time 12.00)
Steel Design - How to build the model and assign design parameters
Krzysztof Wasik
Message 4 of 9
Simau
in reply to: Tmanzz
Hi @Tmanzz
After correcting some geometric errors, the divided main bars were grouped together.
What are the 4 posts for, the concentrated loads being directly applied to the beams.
It would be wise to provide horizontal bracing.
M. Agayr
Message 5 of 9
Tmanzz
in reply to: Simau
Hi Simau,
Thank you for that.
How did you group the divided main bars together?
The 4 posts are just there to show mast sections. They are not really required for the model.
I do have 4 members tying the 2 main beams together.
The idea is to assemble on site so bracing the way you have shown it may be difficult, but I will have a look.
Pls send me  a copy of the corrected model.
Message 6 of 9
Simau
in reply to: Tmanzz
@Tmanzz
In your model nodes 3 6 9 12 are not aligned so you can't grouped them. To do that i used an API (attched)
Model attched
M. Agayr
Message 7 of 9
Simau
in reply to: Simau
You can use at least 4 diagonals (tension compression)
M. Agayr
Message 8 of 9
Tmanzz
in reply to: Simau
Hi @Simau
For the bracing, where would be the best place to install them? Top flange of beam?
Message 9 of 9
Simau
in reply to: Tmanzz
@Tmanzz
At the neutral axis of the beam
M. Agayr
