- Mute
- Permalink
- Report
Hi
I'd like to compose a concrete slab with beams underneath: the beams are spanning between columns, and should work together with the slab.
What's the best way to implement this in Robot?
At the moment, I've defined a slab (let's say 250mm high), and beams (also 250mm high) with an offset so they "touch" the bottom of the slab with their upper part. The total build up will be 500mm. Is this correct, or is there a different method to define a slab with beams at predefined locations?
Thanks!
Artur Kosakowski edited the topic for better findability and marked posts as the solution. If it did not work as an answer, please post your reply in this thread so that I can unmark the solution. Artur Kosakowski
