how to create one drawing for a continuous beam
george.elhaddad
george.elhaddad
Dear all
Is there a way to have a continuous beam on one drawing instead of having different drawings for each span?
Thank you
piperr
Hi, see the link. You have to save every drawing as dxf and merge everything in the same cad file.
Also, check the bar marks, customize the dimensions ,check the laps etc. RSA it's intended to help, not to do your job 🙂
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @george.elhaddad
The way it is shown depends on the selected drawing template:
If one or more of these posts answered your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Artur Kosakowski
george.elhaddad
Thank you Pipper for the tutorial. This is what I used to do, and it takes lot of time to edit and finalize the drawings.
Thanks to Artur, there is always a solution in Robot.
Regards
