How to creat an excel to retrieve Modal table from RSA
WALIDGIO
WALIDGIO
hello,
I want to put a button in my excel to bring me up the modal table from ROBOT 2025 can someone share the code to how to do it ?
also is it possible to insert the Load combination into RSA with a button also
Here the combination example and thank you.
Stephane.kapetanovic
hi @WALIDGIO
you should read these topics
https://forums.autodesk.com/t5/robot-structural-analysis-forum/modal-analysis-results-api/m-p/122698...
https://forums.autodesk.com/t5/robot-structural-analysis-forum/editing-load-cases-in-excel-api/td-p/...
Best Regards
Stéphane Kapetanovic
don't forget to accept the solution and leave a < like !
WALIDGIO
hello thank you for the replay
but its not working in 2025 ROBOT
any solution
Can you explain the error message you are getting ? Have you installed the SDK ?
WALIDGIO
yes the SDK 2025 is installed, I have Office 2021.
ill share the file and the error messages.
HI @WALIDGIO
You've probably chosen a case that isn't a modal case for you
Updated 14/07/24 - Added a drop-down list
Best Regards
WALIDGIO
hi @Stephane.kapetanovic
thank you so m606.uch for your help i have made a lot of progresse
