How to copy uniform planar load on contour
Mr Robot,
I am trying to model a multi-storey RC frame building. I have successfully copied several stories as the layout is fairly reptitive, but I have noticed that the imposed loads (uniform planar load on contour) have not been copied from floor to floor. Is there any way of copying these loads to other floors as the process of mapping out the loads on each floor is very time consuming?
Many Thanks
@Anonymous Artur Kosakowski edited the topic from 'Copying Loadsfor better findability and marked post as the solution. If it did not work as an answer, please post your reply in this thread so that I can unmark the solution.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Try to define this load in the different way.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
ledinhchinh0409
Why RSA does not allow direct replication? hi
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @ledinhchinh0409
The reason is that the contour this type of load is applied to is was not designed as an object type that can be selected and moved from one location to another.
Artur Kosakowski
