How to check utilization ratio RC Design
azraanazhari19
Observer Observer
azraanazhari19
Observer
Observer
I'm doing research using a robot structural analysis, and I don't understand how to check the ratio, is it the same way if you use the method to find the ratio for steel but after I try the value is 0.0, can anyone help me please?
azraanazhari19
Observer
Observer
I have designed a reinforced concrete structure, but I don't know how to see the capacity ratio, is it the same as looking at steel? because when I check like steel the ratio value is only 0.0, can someone help with my problem?
Romanich
Hi @azraanazhari19 ,
For RC elements you can see the capacity ratio only for columns after completing the provided reinforcement design. For example:
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
