How to change the color of selected elements?
memoalcr
memoalcr
How about the color when you select an element? Now, if one selects a bar it turns blue for example. Can one change the selection color to red? (which is easier to see specially when dealing with finite elements
@memoalcr Artur Kosakowski edited the topic from 'Color' for better findability
@memoalcr
yes, see attached picture
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @memoalcr
Has the suggestion posted by @Anonymous (thank you) worked for you? If yes, would you mind marking his post as the solution so that it is easier to find by others? Thank you.
Artur Kosakowski
memoalcr
For RSA 2024, how do you change de selection color for bars to red?
Romanich
Hi @memoalcr
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
memoalcr
thank you
