How to assign a beam to beam splice connection
Hi All,
I was trying to assign a beam to beam splice connection and I found it quite tricky. I did not find the solution anywhere and I by chance found a way. Here is the explanation. I hope it helps somebody.
1. Select node and the two beams connected to them.
2. Then click on 'New connection for selected bars' which will create an end plate connection
3. Click in 'Connection type change' where you can select the beam splice type
mustafahesenow
Mustafa Hesenow
Senior Structural Design Engineer/MZP
LinkedIn
