how I can transfert your model from robot to Autocad Structural Detailing
Message 1 of 10
please give me the option from robot to do that
Replies (9)
Message 2 of 10
Artur.Kosakowski
Autodesk Support
Autodesk Support
The link is available from ASD Steel
Artur Kosakowski
Message 3 of 10
I got my model but how I can show rienforcement detailing of the elements beams ,columns 000000000000000000.png
Message 4 of 10
Artur.Kosakowski
Autodesk Support
Autodesk Support
As ASD Reinforcement is a 2D program this cannot be done. What you can do is to open (and edit) reinforcement drawings generated in Robot or generate them directly in ASD Reinforcement.
Artur Kosakowski
Message 5 of 10
I think there is misunderstand I mean if I could use Relationship between Autodesk Robot Structural Analysis Professional and   AutoCAD Structural Detailing do rienforcement detail like this image :بدون عنوان.png
Message 6 of 10
Artur.Kosakowski
Autodesk Support
Autodesk Support
To achieve such result you need to either open (generated in Robot) or generate (in ASD Reinforcement) reinforcement drawings of each beam, column etc. separately and them 'combine' them by moving them into their 'final' locations. It is not possible to create the view of the entire structure with visible reinforcement at one run as Robot to ASD Reinforcement export.
Artur Kosakowski
Message 7 of 10
how I can generate reinforcing drawing in robot and how to do ('combine' them by moving them into their 'final' location) in ASD can u show me that in image or videos please ?
Message 8 of 10
AhmedZA
hi
try to watch any ASD tutorial on YouTube and you will know how to do that ?
use Move command for any element in order to get the same drawing as you attached above
it will take some time
Message 9 of 10
I do not find any turtoral about this in youtube can u help me if u find ?
Message 10 of 10
AhmedZA
simple case
https://vid.me/0SJu
