How can we input seismic forces and calculate the effects of liquid loads (such as water or oil) on a structure?
anan_nurdinL6WKQ
anan_nurdinL6WKQ
Help please im trying to make a storage tank with hydrostatic pressure, how can i make the force of a sesimic takes into a effect of a liquid
lauri_barnhart
Hello, @anan_nurdinL6WKQ.
Hope you are doing well. Just checking in to see if you found a solution to the problem described above or if you are still needing help. If you still need help, please let us know with as much detail as available by providing a screen recording of the issue in real-time. If you've managed to find a solution, please let us know in detail how you resolved it.
Lauri | Community Manager
Simau
Hi @anan_nurdinL6WKQ
There are many threads about this
https://forums.autodesk.com/t5/forums/searchpage/tab/message?filter=location&q=Tank%20under%20seismi...
M. Agayr
lauri_barnhart
Just checking in to see if the information shared by Simau helped you resolve your question. If it did, please consider clicking on the 'Accept Solution' button. If you still need assistance, please provide an update here.
Best,
