HOW can I prevent to add this res bars(I want single bar overhead)
Artur.Kosakowski
Autodesk Support
Autodesk Support
HI @Anonymous
Could you attach this file?
Artur Kosakowski
when you prove the reinforcement you  are showed you
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
You can use these settings:
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
