How can I mesh the panel/shell so it will ignore the brace?
skilak
skilak
Artur,
in addition, I have a panel/shell and a brace in the same plane. When I mesh the shell, it takes the brace into the meshing. How can I mesh the panel/shell so it will ignore the brace?
Thanks in advance
Artur.Kosakowski
Autodesk Support
Autodesk Support
See the message 4 below.
Artur Kosakowski
skilak
Dzieki,
It works, but the window below needs to be filled with the ignored bars;)
Cheers,
Artur.Kosakowski
Autodesk Support
Autodesk Support
Thanks. Corrected picture below:
Artur Kosakowski
