Get specific nodes and case data in table for printoutcomposition
1234eddie
Message 1 of 16
1234eddie
Hi all,
We @stefanyC6JZ7 and i are currently working on a VBA script that generates images and screencaptures from tables to use in our reports. Thanks to these topics: topic_1 , topic_2  We already solved quite a few things.
But now we want a table, with a specific case and nodes displayed.
these are the nodes (in case 15) i want to display:
But now we get the full table see image
This is our VBA code we have
' Generation of the parametrized Silo.
Public RobApp As RobotApplication
Private Sub CommandButton1_Click()
'***Run Robot application
If RobApp Is Nothing Then
    Set RobApp = CreateObject("Robot.Application")
RobApp.Visible = True
RobApp.Interactive = 1
RobApp.UserControl = True
'***Create an empty Shell project if it has not been created yet
If Not RobApp.Project.IsActive Or RobApp.Project.Type <> I_PT_SHELL Then
       RobApp.Project.New I_PT_SHELL
'Sub kernel()
    'initialisation des valeurs
    Call init_value
    'permet de regénérer la vue
    Call CreeVueRM
    'sauvegarde le projet
    'robapp.Project.SaveAs newfilepath
    'robapp.Project.Close
End Sub
Public Sub CreeVueRM()
  ' définition d'une vue
    RobApp.Interactive = True
    RobApp.Window.Activate
    Dim mavueRobot As IRobotView3 ' this is important to set IRobotView3 if you want to make screen capture of this view
    Set mavueRobot = RobApp.Project.ViewMngr.GetView(1) ' it seems CreateView makes this strange affect, use Get view instead
    Dim SimpleCaseSel As IRobotSelection 'Select Simple cases
    Dim ManualCombSel As IRobotSelection  'Select Combination cases
    mavueRobot.Selection.Get(I_OT_CASE).FromText ("1") ' selecting case for results display
    mavueRobot.Redraw (True)
    'mavueRobot.Projection = I_VP_3DXYZ
    mavueRobot.Projection = I_VP_XZ_3D
    mavueRobot.Visible = True
    RobApp.Project.ViewMngr.Refresh
'---------------------CREATE TABLE
    mavueRobot.Selection.Get(I_OT_CASE).FromText ("15") ' selecting case for results display SLS
    Dim Rtable As RobotTable
    Dim TScPar As RobotTableScreenCaptureParams
    Set TScPar = RobApp.CmpntFactory.Create(I_CT_TABLE_SCREEN_CAPTURE_PARAMS)
    TScPar.Name = "Disp_15"  'Screenshot Name
    'mavueRobot.Selection.Get(I_OT_CASE).FromText ("15") ' selecting case for results display SLS
    'mavueRobot.Selection.Get(I_OT_BAR).FromText ("5")
    'mavueRobot.Selection.Get(I_OT_NODE).FromText ("801 to 829") ' selecting case for results display SLS
    'TScPar.UpdateType = I_SCUT_CURRENT_VIEW
    'TScPar.Resolution = I_VSCR_4096
    mavueRobot.ParamsDisplay.Set I_VDA_STRUCTURE_SUPPORT_SYMBOLS, False 'shows the supports
    mavueRobot.ParamsDisplay.Set I_VDA_STRUCTURE_NODE_NUMBERS, False 'shows the node numbers
    mavueRobot.ParamsDiagram.Set I_VDRT_NTM_MY, False
    mavueRobot.ParamsDiagram.Set I_VDRT_NTM_FX, False
    mavueRobot.ParamsDiagram.Set I_VDRT_NTM_FZ, False
    Set Rtable = RobApp.Project.ViewMngr.CreateTable(I_TT_NODE_DISPLACEMENTS, I_TDT_DISPLACEMENTS)
    'Rtable.Select(IRobotSelectionType.I_ST_CASE, "1")
    ''mavueRobot.Selection.Get().FromText ("15")
    'Dim ScPar As RobotViewScreenCaptureParams
    'Set ScPar = RobApp.CmpntFactory.Create(I_CT_VIEW_SCREEN_CAPTURE_PARAMS)
    'Set Rtable = RobApp.Project.ViewMngr.CreateTable(I_TT_BARS, I_TDT_BAR) ' You can also GetTable
    'Rtable.AddColumn 1  -  modify tables if you want by adding or removing columns
    'mavueRobot.Visible = True
    'mavueRobot.Redraw (True)
    'RobApp.Project.ViewMngr.Refresh
    Rtable.MakeScreenCapture TScPar
    RobApp.Project.PrintEngine.SaveReportToOrganizer
End Sub
At line 120 we did try to select the case but it won't, Does anyone have a solution for this?
From my experience i know that @Rafal.Gaweda is quite familiair with this?
Many thanks in advance.
Replies (15)
Message 2 of 16
Stephane.kapetanovic
hi @1234eddie
remove parentheses from method (when it does not return a value).
you will have to select the nodes also in the table
Best Regards
Stéphane Kapetanovic
don't forget to click the Accept Solution button and leave a < like !
Message 3 of 16
stefanyC6JZ7
Hi @Stephane.kapetanovic
Thank you for your answer. We changed the code as you suggested. And, now it selects the correct case, Case 15, as you can see in the figure below. However, the screencapture of the Table is not done, and I get an error, in the yellow line: "Set TScPar = RobApp.CmpntFactory.Create(I_CT_VIEW_SCREEN_CAPTURE_PARAMS)"
'Sub kernel()
    Call init_value
    Call CreeVueRM
End Sub
    Rtable.Select IRobotSelectionType.I_ST_CASE, "15"
End Sub
Could you check this part of the code?
Thanks in advance.
Best regards,
Stefany
Message 4 of 16
hi @stefanyC6JZ7
  Rtable.Select I_ST_CASE, "15"
  TScPar.Name = "my_results"
Best regards
Message 5 of 16
stefanyC6JZ7
Thank you for your reply, and your help. The code now is working perfectly.  And I get the screenshot. Also, I was wondering if you know how can I set the Page Setup parameters. I am tryint to get them following the path of line 104 " RobApp.Project.PrintEngine.PageSetup.Variables.Active = True". Could you check it please, I am not sure if this is the right way to set the Variables.
Thank you in advance for your help.
Best regards,
Stefany
'Sub kernel()
    Call init_value
    Call CreeVueRM
End Sub
    Rtable.Select IRobotSelectionType.I_ST_CASE, "15" 'Select the Specific Case
    Rtable.Select IRobotSelectionType.I_ST_NODE, "801 to 829" 'Selects the nodes of the last bar
'----------------------HEADERS
    'RobApp.Project.PrintEngine.PageSetup.Header.Active = True
    'RobApp.Project.PrintEngine.PageSetup.Footer.Active = False
    'RobApp.Project.PrintEngine.PageSetup.MarginLeft.Set ("16")
    'RobApp.Project IRobot.VariablePredefinedId.I_VPI_PROJECT_NAME, "Trials"
    'Dim Headers As IRobotVariablePredefinedId
    'Set Headers = RobApp.Project.Printouts.IRobotVariablePredefinedId (8)
    'Headers.I_VPI_USER_ADDRESS , "Trials"
End Sub
Message 6 of 16
RobotVariableMngr has no Active property, could you be clearer on what you want to set by RobApp.Project.PrintEngine.PageSetup.Variables? For example you have a SetPredefinedValue method that can help you.
Message 7 of 16
stefanyC6JZ7
hI @Stephane.kapetanovic
I want to edit the Page Setup Parameters, For example, "PROJECT_ADDRESS1" as figure below shows. I want to use  VBA to assign the Values instead of doing manually.
I was checking the API Documentation and I found that IRobotPageSetup has the Field Variables as the figure below shows.
Also,  I Found the  IRobotVariablePredefinedId with some Parameters. As figure below shows.
I am not sure how to do it with VBA, Could you help me to check if the following code is correct to edit the variables, or what should I do?
Best regards,
Stefany
Message 8 of 16
as suggested you can use the SetPredefinedValue method.
  RobApp.Project.PrintEngine.PageSetup.Variables.SetPredefinedValue I_VPI_PROJECT_ADDRESS1, "MyProjectAdress"
Message 9 of 16
stefanyC6JZ7
Thank you for your answer, now it works fine.
Best regards,
Stefany
Message 10 of 16
stefanyC6JZ7
Sorry to bother you again. Could you help me to solve a question about Printout composition.
I want to add the standard Tables (Data - Nodes, Data -Members, etc), from Printout composition, Standard Tab to my Printout list on the right as figure shows, using VBA instead of adding them manually.
I was checking the API Documentation, and I am not sure if it is correct to add them as follows:
Set Rtable1 = RobApp.Project.ViewMngr.GetTable(I_TT_NODES, I_TDT_DEFAULT)
First, by using Get Table, please find the code below. Then, by adding
Dim Rtable1 As RobotTable
    Dim TScPar1 As RobotTableScreenCaptureParams
    Set TScPar1 = RobApp.CmpntFactory.Create(I_CT_TABLE_SCREEN_CAPTURE_PARAMS)
    TScPar1.Name = "Disp_Nodes Table"  'Screenshot Name
    TScPar1.UpdateType = IRobotViewScreenCaptureUpdateType.I_SCUT_CURRENT_VIEW
    'TScPar1.Resolution = IRobotViewScreenCaptureResolution.I_VSCR_4096
    Rtable.MakeScreenCapture TScPar1
Message 11 of 16
hi @stefanyC6JZ7
rather than using the get method, use the create method and close the window after use.
With RobApp
  Set TScPar = .CmpntFactory.Create(I_CT_TABLE_SCREEN_CAPTURE_PARAMS)
  Set Rtable = .Project.ViewMngr.CreateTable(I_TT_NODES, I_TDT_NODE)
End With
TScPar.Name = "myNodeTable"
Rtable.Window.SendMessage &H10, 0, 0
for the get method an example is below
https://forums.autodesk.com/t5/robot-structural-analysis-forum/api-macro-for-dumping-all-opened-tabl...
Best Regards
Message 12 of 16
stefanyC6JZ7
Thank you for your answer. You are right, I can get the tables. However, I got one issue in the creation of the Support Table.
When I take it manually I got the table shown below.
But when I try it with the following code, I get a different table.
'--------------------Add Standard Data-Supports
    Dim Rtable5 As RobotTable
    Dim TScPar5 As RobotTableScreenCaptureParams 'To create a table
    Set TScPar5 = RobApp.CmpntFactory.Create(I_CT_TABLE_SCREEN_CAPTURE_PARAMS)
    With RobApp
    Set TScPar5 = .CmpntFactory.Create(I_CT_TABLE_SCREEN_CAPTURE_PARAMS)
    Set Rtable5 = .Project.ViewMngr.CreateTable(I_TT_SUPPORTS, I_TDT_SUPPORTS)
    End With
    TScPar5.Name = "Data - Supports"
    Rtable5.MakeScreenCapture TScPar5
I am not sure what is wrong, Could you help me to check it?
Thank you in advance.
Best regards,
Stefany
Message 13 of 16
hi @stefanyC6JZ7
the two main methods are those detailed above, if the presentation proves to be complicated to do by programming or that it only occurs in rare cases, it is probably possible manually by you. In your case, it may be more practical to use the Get method on a previously formatted table.
Best Regards
Message 14 of 16
stefanyC6JZ7
Thank you for your response @Stephane.kapetanovic. I checked again the API documentation and using the code below, the right table appears.
Set Rtable0 = RobApp.Project.ViewMngr.CreateTable(I_TT_SUPPORTS_LABEL, I_TDT_SUPPORTS)
 Thank you for your help.
Best regards,
Stefany
Message 15 of 16
stefanyC6JZ7
Sorry to bother you again. Could you help me to solve one issue when selecting specific nodes using VBA.
I want to create this table, as figure below shows. The table shows the node displacement from Bar 5, containing nodes 801-829.
Currently I am using the code below:
 ''Sub kernel()
    Call init_value
    Call CreeVueRM
End Sub
    ''RobApp.Project.ViewMngr.Refresh
    '-------------------------------SELECT NODES
    Dim NodeSel As RobotSelection  'Node selection
    Set NodeSel = RobApp.Project.Structure.Selections.Get(I_OT_NODE) 'Selects all nodes
    NodeSel.FromText "all"
    Dim Node As RobotObjObject
    Dim NodeCol As RobotNodeCollection
    Set NodeCol = RobApp.Project.Structure.Nodes.GetMany(NodeSel)
    Dim NodesSelection As String
    Row = 2
    For ii = 1 To NodeCol.Count
        Cells(Row, 9) = "Node"
        Set RNode = NodeCol.Get(ii)
        Cells(Row, 10) = RNode.Number
        Row = Row + 1
    Next ii
    Dim i As Integer
    Dim firstRow As Integer
    Dim columnNumber As Integer
    Dim Max As Integer
    Z = 801
    firstRow = 2
    columnNumber = 10
    Set Sheet = ActiveSheet
    If Sheet.UsedRange.Rows.Count <= 1 Then Max = NaN Else Max = Sheet.Cells(firstRow, columnNumber)
    For i = firstRow + 1 To Sheet.UsedRange.Rows.Count
        If Sheet.Cells(i, columnNumber) > Max Then Max = Sheet.Cells(i, columnNumber)
    Next
        Cells(1, 9) = "Node_Max"
        Cells(1, 10) = Max
        V = Max
        Cells(1, 11) = "Node_Start"
        Cells(1, 12) = Z
    Rtable.Select IRobotSelectionType.I_ST_CASE, 15 'Select the Specific Case
    Rtable.Select IRobotSelectionType.I_ST_NODE, "801to829"  'Selects the nodes of the last bar
End Sub
When creating the table, the code selects from node 801 to node 829.
However, the maximum node number("829") will change depending on the project. Thats why the approach is to get the maximum node number from all the nodes. And then create the table from node 801 - Node_max number.
With the current code, I get succesfully the Node_Max number ("829") and export to Excel as fiure below shows:
And If I change the part of the code as follows:
Rtable.Select IRobotSelectionType.I_ST_NODE, V  'Selects the nodes of the last bar
I got the following table, witht the right case and the max node mnumber:
But I am not sure how to create the table from node 801to829 using V instead of 829.
Rtable.Select IRobotSelectionType.I_ST_NODE, "801toV"  'Selects the nodes of the last bar
Could you help me to chekc if this is the correct way to get the table?
Best regards,
Stefany
Message 16 of 16
hi @stefanyC6JZ7
The code below will give you the first and last number as well as the overall selection of nodes in your project.
With RobApp.Project.Structure.Selections.Create(I_OT_NODE)
  .FromText "all": First = .Get(1): Last = .Get(.Count): TxtFirstToLastNode = .ToText
End With
used like that
Rtable.Select IRobotSelectionType.I_ST_NODE, TxtFirstToLastNode
Best Regards
not knowing your project, note that you can also write:
TxtFirstToLastNode = "801to" & Last
