Get Node Displacement Results using CPython3
stefanyC6JZ7
stefanyC6JZ7
Hi all,
We are currently upgrading our scripts from IronPhyton 2 to CPhyton 3.
I want to get the results of node displacement using CPython3. The code in IronPython2 cretes 6 lists of results in UX,UY,UZ,RX,RY,and RZ, please see picture below.
In CPython3 I get the following error: Warning: AttributeError : '__ComObject' object has no attribute 'UX' [' File "<string>", line 41, in <module>\n'].
import clr
clr.AddReference('ProtoGeometry')
from Autodesk.DesignScript.Geometry import *
# add Robot Structural Analysis API reference
from System import Environment
# get the current user folder i.e C:\Users\<you>\AppData\Roaming
user = Environment.GetFolderPath(Environment.SpecialFolder.ApplicationData)
sys.path.append(user+r"\Dynamo\Dynamo Core\2.11\packages\Structural Analysis for Dynamo\bin\RSA\Interop.RobotOM.dll")
clr.AddReference('interop.RobotOM')
#clr.AddReference(user+r"\Dynamo\Dynamo Core\2.11\packages\Structural Analysis for Dynamo\bin\RSA\Interop.RobotOM.dll")
# add needed import to be able to use Robot Structural Analysis objects
from RobotOM import *
from System import Object
# get input data
# input 0 is just a result that indicates if the calculation ran ok.
# also makes sure we get loads AFTER running analysis.
calculateOutcome = IN[0]
# list of robot bar IDs that you want loads from:
inputNodeIDs = IN[1]
All_Case_Comb_nr = IN[2]
# Connect to the running instance of Robot Structural Analysis
application = RobotApplicationClass()
# Get a reference of the current project
project = application.Project
structure = project.Structure
NodeDisplacement = []
NodeDisplacement.append([])
node =  IRobotNodeDisplacementServer
node_dis = IRobotDisplacementData
for l in range(len(All_Case_Comb_nr)):
    NodeDisplacement[0].append(structure.Results.Nodes.Displacements.Value(inputNodeIDs[0],All_Case_Comb_nr[l]).UX*1000)
    NodeDisplacement[1].append(structure.Results.Nodes.Displacements.Value(inputNodeIDs[0],All_Case_Comb_nr[l]).UY*1000)
    NodeDisplacement[2].append(structure.Results.Nodes.Displacements.Value(inputNodeIDs[0],All_Case_Comb_nr[l]).UZ*1000)
    NodeDisplacement[3].append(structure.Results.Nodes.Displacements.Value(inputNodeIDs[0],All_Case_Comb_nr[l]).RX*1000)
    NodeDisplacement[4].append(structure.Results.Nodes.Displacements.Value(inputNodeIDs[0],All_Case_Comb_nr[l]).RY*1000)
    NodeDisplacement[5].append(structure.Results.Nodes.Displacements.Value(inputNodeIDs[0],All_Case_Comb_nr[l]).RZ*1000)
    OUT = NodeDisplacement
I have been trying to change the code with the following classes, but It is not working.
Could you help me to solve the issue?
Thank you in advance.
Best regards,
Stefany
stefanyC6JZ7
Hi all,
I have seen your names in similar topics, maybe one of you can help me out?
@JacquesGaudin @cool.stuff @chjpcoi
Best regards,
Stefany
JacquesGaudin
I think this one is quite easy, just cast the result of the `Value` method to IRobotDisplacementData and it should be ok.
Note that rather than calling six time the `Value` method, you're better off calling it once and storing the result in a variable.
import clr
# get input data
    disp_value = IRobotDisplacementData(structure.Results.Nodes.Displacements.Value(
        inputNodeIDs[0],
        All_Case_Comb_nr[l]
    NodeDisplacement[0].append(disp_value.UX*1000)
    NodeDisplacement[1].append(disp_value.UY*1000)
    NodeDisplacement[2].append(disp_value.UZ*1000)
    NodeDisplacement[3].append(disp_value.RX*1000)
    NodeDisplacement[4].append(disp_value.RY*1000)
    NodeDisplacement[5].append(disp_value.RZ*1000)
