Geometry of element requires treatment of the element as Wall piers
Message 1 of 13
I get this message: Geometry of element requires treatment of the element as Wall piers. The RC Wall module does not support this type of elements. Thank you for your attention
Replies (12)
Message 2 of 13
Could you attach your model?
Message 3 of 13
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Assuming you selected ACI code this message is displayed when Hw/Lw >= 2.0 and Lw/Bw <= 6.
Bw – thickness
Hw – height
Lw – length
@Anonymous Thank you for your contribution to this forum.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Message 4 of 13
The verification is according to the code ACI 318, taking the suggestion is verified that it complies, but the same I still get the error message ...
Message 5 of 13
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Could you attach the file with this model?
Artur Kosakowski
Message 6 of 13
Message 7 of 13
Your Hw/Lw=3,36 > 2 and Lw/Bw=4,9<6 so your wall is treated as a wall pier.
Message 8 of 13
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Am I correct that @Anonymous (thank you) already provided the answer for you?
Artur Kosakowski
Message 9 of 13
I have no response from @Anonymous
Message 10 of 13
2 posts earlier was:
Your Hw/Lw=3,36 > 2 and Lw/Bw=4,9<6 so your wall is treated as a wall pier."
Cheers.
Message 11 of 13
Thank you very much, the procedure through illustrations using images or video, how to solve this message ... thank you very much for the attention paid ...
Message 12 of 13
Hi @Anonymous,
To solve this message you have to change dimensions for the wall.
As I understand this ACI standard doesn't take in to account wall that you try to design.
Message 13 of 13
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
My knowledge of ACI it  too limited to be sure but perhaps you just need to design it as a column (model it as a bar element instead)?
http://www.eng-tips.com/viewthread.cfm?qid=379105
Artur Kosakowski
