Generate EC8 General seismic case through API
Hello to everyone,
I have a problem when I want to generate a seismic case according to EC8 General via VBA.
The code I wrote is the following:
Dim EQLoad As RobotSimpleCase
    Dim ECParams As RobotSeismicAnalysis_EC8_General_Params
    Dim ModalParams As RobotModalAnalysisParams
    If Not Robapp.Visible Then
        Set Robapp = Nothing
        MsgBox "Open Robot and load Model", vbOKOnly, "ERROR"
        Exit Sub
    Else
        Set EQLoad = Robapp.Project.Structure.Cases.CreateSimple(100, "Modal", I_CN_EXPLOATATION, I_CAT_DYNAMIC_MODAL)
        Set ModalParams = EQLoad.GetAnalysisParams
        ModalParams.ModesCount = 20
        EQLoad.SetAnalysisParams ModalParams
        Set EQLoad = Robapp.Project.Structure.Cases.CreateSimple(200, "EarthQuake+X", I_CN_SEISMIC, I_CAT_DYNAMIC_SEISMIC)
        Set ECParams = EQLoad.GetAnalysisParams
        ECParams.Ag = Foglio2.Range("F9")
        ECParams.B = 0.2
        ECParams.BehaviorFactor = Foglio2.Range("F14")
        ECParams.DirectionType = I_SADT_HORIZONTAL
        ECParams.Direction.Set 1, 0, 0
        ECParams.ExcitationDir.ResolutionActive = True
        ECParams.S = Foglio2.Range("F5")
        ECParams.Spectrum = I_SAST_DIMENSIONING
        ECParams.Tb = Foglio2.Range("F6")
        ECParams.Tc = Foglio2.Range("F7")
        ECParams.Td = Foglio2.Range("F8")
        Set EQLoad = Robapp.Project.Structure.Cases.CreateSimple(201, "EarthQuake+Y", I_CN_SEISMIC, I_CAT_DYNAMIC_SEISMIC)
        ECParams.B = 0.2
        ECParams.Direction.Set 0, 1, 0
What is it wrong in it?
I receive a Type Mismatch error when the line
try to run.
Has someone the solution or an example which explain how to do it?
Thank you in advance!
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
These Params are implemented for EN 1998-1:2004/A1:2013
Example code:
Dim EC_Params  As RobotSeismicAnalysis_EC_8_Params
Dim RCase As RobotSimpleCase
Set RCase = Robapp.Project.Structure.Cases.CreateSimple(Robapp.Project.Structure.Cases.FreeNumber, "Modal", I_CN_PERMANENT, I_CAT_DYNAMIC_MODAL)
Set RCase = Robapp.Project.Structure.Cases.CreateSimple(Robapp.Project.Structure.Cases.FreeNumber, "Seismic EC", I_CN_SEISMIC, I_CAT_DYNAMIC_SEISMIC)
aaa = RCase.GetSeismicCode
Set EC_Params = RCase.GetAnalysisParams
EC_Params.BehaviorFactor = 1#
EC_Params.Direction.Set 1, 1, 1
EC_Params.DirectionType = I_SADT_HORIZONTAL
EC_Params.SoilClass = I_SAST_EC_8_SOIL_A
EC_Params.SpectrumType = I_SAST_DIMENSIONING
EC_Params.StructureType = I_SAST_EC_8_B
EC_Params.ZoneType = I_SAZT_EC_8_IA
RCase.SetAnalysisParams EC_Params
Rafal Gaweda
Hi @Rafal.Gaweda,
thank you for your reply. However, I asked for the General EC 8, not the standard. This because I need to define the Tb, Tc, Td (and so on) parameters instead of the parameters given in the other EC8 parameters.
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
So :
Dim EC_Params  As RobotSeismicAnalysis_EC8_General_Params
EC_Params.Ag = 1
EC_Params.B = 1
EC_Params.Tb = 1
Rafal Gaweda
Yes, exactly what I wrote before. the problem was that when running, the program gave me an error of type mismatch.
But I found the solution: in the model, in job preferences, the code for loads was set to EC8 and not the General one. Changing this setting, the program runs correctly. 🙂
It is sufficient to add the following code before creating loads:
Robapp.Project.Preferences.SetActiveCode I_CT_SEISMIC_LOADS, "EN 1998-1:2004/A1:2013-General"
