I am designing a foundation and when it comes to the loads it seems Robot is not taking the reactions from the model.
Should I insert them manually? In this case is pretty simple but I wanted to know why is not working properly. I have modified a reinforcement bars database but I do not think that could be the reason.
Thank you
Solved by Simau. Go to Solution.
Hi @mikelt6CWRJ
If you followed this step and checked combinations, loads will be taken into account
See calculation note
M. Agayr
Thank you. It seems now it is taking the loads:
However, now I am facing another error,"Safety factor of top reinforcement in the direction of X axis : 0.00 < 1.0". I have checked the explanation here and I switched off the Freeze reinforcement option, but I am geeting the same error message:
I was thinking this message is because of the user defined reinforcement bars. Also I am geeting a message of "Condition not met for: Foundation uplift in state of ULS", which I do not understand as the foundation clearly weights more that the vertical reaction I have (34 kN).
Thank you
Uncheck these boxes
M. Agayr
Thank you.
Here I should give more context to the situation. What I am doing with this design is checking an existing desing which has those dimensions. The given design has the error and shows the following results and I do not get reinforcement design:
If I switch off that option I do not get that error as you explained:
Like I said, I do not really get why this foundation. Where can I check the figures? In the foundation note I only get this related with the uplift when I do as you said:
Thank you
Hello all,
I think I find the problem. I reduced the excentricity limitation, I had A/6 as default:
https://help.autodesk.com/view/RSAPRO/2024/ENU/?guid=GUID-8E6475AE-CAD9-4A0D-82A0-0B98CBA2D845
Threfore, I select the following option:
And then, I get the results. Of course this a matter of how we, as designers, interpret the standard.
Best regards
