Foundation sliding
Foundation sliding
JPNR87
Foundation sliding
JPNR87
I have foundation block on ground. Sliding area considered very large and also Ppx and Ppy.
Does Robot allow to calculate foundation on ground?
Thanks!
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @JPNR87
You don't have any issue with the sliding but with the soil capacity instead:
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
JPNR87
sliding is related to soil and I dont understand why so big numbers. Any idea?:
Thanks for answer!
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @JPNR87
I'm not sure if I  understand the situation correctly. The sliding much smaller than the horizontal size of the foundation. Is your perception due to units mm2 instead of m2?
Artur Kosakowski
JPNR87
The problem is when foundation upper part is to close to ground surface no sliding resistance is presented ("0").
Is robot using Hansen's method for sliding?
Thanks for answers!
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @JPNR87
Check the attached foundation.
Check: Robot Structural Analysis 2019 Help: Sliding
Artur Kosakowski
