Wind load simulation
I'm doing a wind load simulation in Robot for a 28 story building. I have model the structure of the building and put claddings around the building for the wind load simulation. When the simulation is started, the Robot software get stuck at the meshing stage ( I have attached an image). What could be the reason for this?
Thanks in Advance.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
What is you wind simulation profile?
Artur Kosakowski
Hi @Artur.Kosakowski,
This is the wind profile I'm using. (Image attached)
Thank you.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Could you attach the model?
Artur Kosakowski
Can I send you it privately?
Can I send you the model to you privately?
Thank you.
