Foundation design
Foundation design
Foundation design
Hi, I don't have the RC foundation design or RC foundation design bottoms on robot
 how I can get these options, please?
Artur.Kosakowski
Autodesk Support
Autodesk Support
I'm not sure if I understand this situation correctly. Could you make a screen capture that illustrates this issue please?
Artur Kosakowski
OK, I will do,
the situation I work with revit structure model with spread footing , when export the model to robot I couldnt design the footing , i dont have the tool for that,
Artur.Kosakowski
Autodesk Support
Autodesk Support
After calculating the model in Robot select  a spread footing (the same for a beam, a column etc.) and press the indicated button. This will ex[port the selected object to the appropriate RC Design module.
Artur Kosakowski
