ear Sir/Madam,
I would like know how to model correctly Flat Steel Plate with correct steel material properties ?
Looking forward to hearing from you.
Yours faithfully
Nissar
ear Sir/Madam,
Yours faithfully
Nissar
Solved by Krzysztof_Wasik. Go to Solution.
Hi @Nissar19
Plate geometry can be defined by Geometry >Objects >Polyline contour.
Then Panel can be assigned to defined geometry (Geometry >Panel).
While panel definition, thickness can be edited "..."and defined as for homogeneous plate.
Within thickness definition dialog, material can be selected from material database.
Model - in panel definition dialog should be set to shell.
Reinforcement does not matter while calculation but can be set to none.
Hi @Nissar19
Thanks a lot.
