flat slab required reinforcement
ewu168
ewu168
Hi Autur,
I can not analyse this structure neither by Required Reinforcement nor Provided Reinforcement method,
please take a look into the model attached,
Your prompt reply would be much appreciated,
Regards
Eric
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi Eric,
Check the material you assigned to elements of the model
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
