Flat slab design - long term elastic modulus - deflection
skellyRSA2023
skellyRSA2023
when design an RC flat slab generally when using looking at deflections I use the long term elastic modulus say short elastic modulus values for E, which I would have thought would give conservative deflection values , however I have run the model with a C40 concrete with a E value of 28,000 short term and 7,000 long term and I am getting less deflection with the long term E value? is this correct? I would have though this would be the opposite? any help or suggestions would be appreciated.
Simon.
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @skellyRSA2023
I cannot see your model but good practice for material properties modification is to define new material name.
Probably you have not changed material name while E modification and in that case material properties are not updated automatically in model.
While material modification, new material name should be defined "C40 -reduced" then material should be changed in panel thickness definition dialog.
Panels deflection should be bigger once material E is reduced.
For RC slab long therm deflection calculation, RC required reinforcement module can be used.
See slab design section of   RC design in Robot Structural Analysis
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Krzysztof Wasik
