Fixed beam-to-beam connection EN 1993-1-8; p - parameter
KamikonLK
KamikonLK
How is calculated p parameter "distance between bolts"?
In the attached example the distance between bolts is 170 mm, and p = 58.0 and 70.0.
Any ideas why?
ARSA 2016 SP.2
Artur.Kosakowski
Autodesk Support
Autodesk Support
For such arrangements of bolts p is calculated as doubled value of the distance from the line of bolts to the edge of the beam. In fact these values should not be displayed in the note as it is not used in the verification of this type of connections.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
