First Seismic Analysis. Chek result. Slab foundation on winkler Springs.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi , I’m Italian student and this is my first model in this amazing software. Sorry for my english. I've lot of question, and glad to have your help.
- Seismic analysis (i don't count eccentricy in analysis to avoid an increase of analysis time): Modes: much modes with low participating mass, so i can use 300 modes to reach 85% partecipating mass, because of:
- Vertical action
- Mixt structure reinforced concrete wall + column steel
Is this observations right? is it possible that a lumped mass matrix it's a wrong model in this case?
- Cases: I create my SLE (SLS) and SLU (ULS) cases. But when i created Seismic Analysis, they appeared a lot of case that i don't know and im not able to delete: SLE:CHR; SLE:FRE; SLE:QPR what's that?
- Load to mass conversion: I converted load into mass. I didn't pin Disregard Density, and i dont' convert into dynamic mass DL (Dead Load) is it correct?
- Plate Foundation on winkler springs: I try to create a model with springs, but it too slow to work on it. So i prefered to use a fixed model, and analyze and rebar plate apart.
Now, how can i carry out stress and forces from column and Wall to my plate in another file to analyize my plate? - Plate Foundation Support: when i applied Springs, i noticed that i can define and applied elastic coefficent (Kz) in two different screens, first: in Thickness definition i can apply my elastic coefficent. Then in Support i can define my springs with Kz coefficent. Should insert Kz in all of this?
Thanks in advance.
