Finite Element Mesh Local Axis
Victor_Huang1
Victor_Huang1
Hi All,
I am designing a drainage pit using finite element. Is it necessary to have all surface having the same local axis direction?
Also, is it possible to change the local axis for all surface to be the same as the global axis?
Regards;
victor
Simau
Hi @Victor_Huang1
not necessary but preferable.
To change local axis:
Geometry > Properties > Local Panel Direction
M. Agayr
Rafacascudo
Also, is it possible to change the local axis for all surface to be the same as the global axis?"
Only if panel is on a XY global plane.
Because panel  Local Z will always be perpendicular to the panel plane
Rafael Medeiros
